hi from french britanny
zab
9
1
Hi guys
I subscribe because I am currently working on 2010 XF V6 3.0
The first problem was the blocked glove box, I find the solution on the forum and I will add a push button next to it to open it
The second problem happened during the operation, it seems that the fuse nbr 35 (interior lighting) blows instantly.
I removed the lights from the sun visors but still the same, I did not have time to look for more.
Finally the owner wants to change the sound of the exhaust and I ask to install valves as soon as he activates the sport mode, however since it is a diesel, I think there is a good chance that faults will appear. .
What solutions can I offer it?
Thank you and good day
Paul in NE
Senior member
441
254
83
County Durham
Hi guys
Not sure what you are expecting in terms of different exhaust noise from a turbo diesel... The turbos do a good job as silencers and there's not a lot of 'sporty noise' to be liberated. An increase in pipe diameter downstream of the turbo would allow it to spool up faster and liberate a little more mid range torque. You will get a slightly different, deeper note from the tailpipes but not exactly 'rorty'.. .
The main advantage of changing silencer boxes/tailpipes (either deleting or changing to 'straight through' design) will be cosmetic, a little less restriction to gas flow and less weight. I would suggest theres no real need for rear silencers at all on a turbo diesel. Others may disagree.
If you're looking for cosmetic improvements, fair enough, but in terms of performance gains it's nowhere near as cost effective as a re-map.
Having said all this, I went with a less restrictive stainless steel system, changing from the hidden, downturned original tailpipe on my X-Type 2.2D to a twin exit design. There are a few reputable companies who can accommodate your requirements and I would certainly reccommend you check out Elite and Performance Jags in Derby. They have a video clip online showing their 'Elite RR' back box system.
zab
9
1
Yes i know that the noise for diesel engines is difficult to change, that why i prefer ask owners to find a good solution, i don t want to tell him to buy some parts and have no results. Thanks for the recommandations.
