How To Guides version 1.0
Goudy
3,455
1
I thought about trying to reconstruct SOME of the "How to" Guides.
They aren't all here as some are hard to track down, but I've done my best as I had some time on my hands.
The very first thread is here, if you remember where some are, please PM me the link and I will try to update this.
http://www.jaguarforum.co.uk/f26/how-guides-links-only-no-comments-discussion-36538.html
Please note, some are external links and therefore have a limit to there access.
Audio Connectivity Module (ACM) Instalation Guide
http://www.keepandshare.com/doc/2849749/jx-acc-acm-instal-pdf-june-3-2011-8-58-pm-1-3-meg?da=y
EGR Valves parts and accessories
http://www.keepandshare.com/doc/2849750/jx-inf-egr-valve-types-pdf-june-3-2011-8-58-pm-472k?da=y
EGR Cleaning Guide - 2.2D (non-DPF) stepper motor version
http://www.keepandshare.com/doc/2849751/jx-egr-cleaning-pdf-june-3-2011-8-58-pm-167k?da=y
EGR valve fault codes P0406 & P0402
http://www.jaguarforum.co.uk/f26/p0406-p0402-egr-fault-code-39322.html
Jim's Little Black Book - Variety of Useful Tips & Routines for X-Type Owners
http://www.keepandshare.com/doc/2849752/jx-inf-tips-routines-pdf-june-3-2011-8-58-pm-800k?da=y
Rear Bumper Protector (Estate)
http://www.feebs.co.uk/Jag/slides/index.html#slides/DSC02812.JPG
Window Blinds (Estate)
http://www.feebs.co.uk/Jag/shades/index.html
D2B Linking Fibre Optic Cables
http://www.keepandshare.com/doc/288...tic-cables-pdf-june-19-2011-8-45-pm-414k?da=y
Under the Bonnet - pictorial guide to what is where
http://www.keepandshare.com/doc/2869865/jx-inf-under-the-bonnet-pdf-june-13-2011-11-18-pm-363k?da=y
Cam Position Sensor (CMP) - Diesel Removal
http://www.keepandshare.com/doc/285...-sensor-cmp-pdf-june-7-2011-6-57-pm-926k?da=y
Aux Power Sockets (Fitting) - rear with pics
http://www.jaguarforum.co.uk/f26/auxiliary-power-sockets-36797.html
MAF Sensor Cleaning 08MY 2.2D (non DPF)
http://www.keepandshare.com/doc/2854281/jx-inf-maf-sensor-clean-pdf-june-6-2011-6-11-pm-803k?da=y
Transfer Box Removal
http://www.jaguarforum.co.uk/f26/how-replace-transfer-box-36534.html
spark plug change in v6 x type
http://www.jaguarforum.co.uk/f26/spark-plug-change-2-1-x-type-sport-37309.html
Autofold with memory
http://www.jaguarforum.co.uk/f26/how-fit-autofold-mirrors-memory-cars-36703.html
Changing Gear Stick Gaitor
http://www.redlinegoods.com/XType0105install.php]Jaguar X-Type 2001-05 shift boot installation - RedlineGoods leather shift boot store
http://www.jaguarforum.co.uk/f26/gear-stick-handbrake-gaiters-23603.html
Full size 18" spare wheel does it fit in the estate wheel well ?
http://i20.photobucket.com/albums/b246/phil900/P2151249.jpg
Retro fit Sat Nav
http://www.jaguarforum.co.uk/f26/retrofitting-touch-screen-sat-nav-controls-7735.html
Retrofit Bluetooth without Pre-Wire
http://www.jaguarforum.co.uk/f26/deletion-phone-voice-pre-wire-35635-2.html#post372456
Retrofit Electric Seats
http://www.jaguarforum.co.uk/f26/electric-chair-retrofit-38552.html
Retrofit Puddle Lights
http://www.jaguarforum.co.uk/f26/puddle-light-fitting-36020-2.html#post406642
http://www.jaguarforum.co.uk/f25/audio-connectivity-module-acm-faq%92s-tips-tricks-39352.html
SatNav Disc Information
http://www.jaguarforum.co.uk/f25/navigation-discs-faq-links-official-sources-38957.html
Retro fit Premium Sound
http://www.jaguarforum.co.uk/f26/premium-sound-retrofit-%96-extended-version-40467.html
http://www.jaguarforum.co.uk/f26/retro-fit-premium-sound-5476.html
How to change the (cabin) Pollen Air Filter with Photos
http://www.jaguarforum.co.uk/f26/pollen-cabin-filter-replaced-photos-37409.html
How to Auto Fold Wing Mirrors on Double Lock(none memory)(with photos)
http://www.jaguarforum.co.uk/f26/how-auto-fold-wing-mirrors-double-lock-photos-36529.html
EGR Removal and Cleaned (with photos)
http://www.jaguarforum.co.uk/f26/egr-removal-cleaned-photos-36133.html
De-Chromed and Changed to a Sports Grill (with photos)
http://www.jaguarforum.co.uk/f26/de-chromed-changed-sports-grill-photos-36344.html
Emergency Boot Access
http://www.jaguarforum.co.uk/f26/emergency-boot-access-37454.html
2.2 estate 06 plate inner CV Boot change on the nearside
http://www.mediafire.com/?zu0tullcexja5/URL]Free Cloud Storage - MediaFire
HOW TO CHANGE THE LOOK OF YOUR DASHBOARD (with photos)
http://www.jaguarforum.co.uk/f26/how-change-your-dashboard-look-photos-37783.html
Estate Beesting Aerial Fittings & Repair
http://www.jaguarforum.co.uk/f26/appalling-radio-37642.html
Filters and Oil Change for Diesel
http://www.jaguarforum.co.uk/f26/filters-oil-change-diesel-37862.html
Fitting front window wind deflectors
http://www.jaguarforum.co.uk/f26/front-wind-deflector-fitting-37953.html
Solid Flywheel Conversion 2.0d Euro III
http://www.danieloregan.ie/dmcs/flywheel.pdf
Joining Wires (12v)
http://www.keepandshare.com/doc/3001637/article-joining-wires-pdf-july-23-2011-11-40-am-393k?da=y
Floppy Sun Visors (Vanity mirrors) Fixed (with photos)
http://www.jaguarforum.co.uk/f26/floppy-sun-visors-fixed-photos-38011.html
Diagnosing Problems - Jaguar Diagnostic Theory
http://www.keepandshare.com/doc/3002112/j-tinf-diagnostic-theory-pdf-july-23-2011-9-56-pm-393k?da=y
Front and Rear Door Card Fasteners Location
http://www.keepandshare.com/doc/300...-fasteners-pdf-july-24-2011-1-43-pm-151k?da=y
Front Door Card Removal (with pics)
http://www.keepandshare.com/doc/3002946/jx-inf-door-card-removal-pdf-july-24-2011-1-43-pm-286k?da=y
Sat Nav Installing Update Map & Software DVD
http://www.jaguarforum.co.uk/f26/new-nav-dvd-38132.html
Squeaking / Creaking Seat - Cured!
http://www.jaguarforum.co.uk/f26/squeaking-seat-cured-38236.html
Auxiliary Belt Change
http://www.jaguarforum.co.uk/f26/auxiliary-belt-tensioner-37499.html
http://www.jaguarforum.co.uk/f26/jaguar-x-type-drumming-idle-40673.html
http://www.jaguarforum.co.uk/f26/recently-fitted-aux-belt-tensioner-40040.html
http://www.jaguarforum.co.uk/f26/alternator-belt-tensioner-crank-pulley-easy-method-47273.html
Retro Fit Cruise Control (AWD cars only)
http://www.jaguarforum.co.uk/f26/retro-fit-cruise-update-38596.html
Retro Fit Cruise Control (Diesel)
http://www.jaguarforum.co.uk/f26/retro-fitting-cruise-control-x-type-diesel-2-0d-46493-2.html
http://www.talkford.com/topic/113522-retrofit-control-cruise/]Retrofit Control Cruise ? - Electrical (Mk3 Mondeo) - TalkFord.com
Access to Estate High Level Brake LEDs and Washer Pipes (with Pics)
http://www.jaguarforum.co.uk/f26/access-estate-high-level-brake-leds-washer-pipe-pics-38710.html
Checklist for Rear Suspension Noise
http://www.jaguarforum.co.uk/f26/checklist-rear-suspension-noises-38995.html
Retrofit Trip Computer / Message Centre / Instrument Cluster
http://www.jaguarforum.co.uk/f26/retrofitting-trip-computer-32800.html
Heated Washer Jets
http://www.jaguarforum.co.uk/f26/heated-washer-jets-30605.html
PowerWash Jets - Easy Access
http://www.jaguarforum.co.uk/f26/little-trick-get-your-powerwash-jets-out-39766.html
Petrol in Limp Mode?...Check this first
http://www.jaguarforum.co.uk/f26/engine-light-fixed-£3-17913.html
Strut Removal Guide
http://www.jaguarforum.co.uk/f26/strut-removal-guide-40184.html
Locking Wheel Nut Removal
http://www.jaguarforum.co.uk/f26/x-type-locking-wheel-nut-removal-25952-2.html
Turbo Strip & Clean (Garrett)
http://www.technologie-entwicklung.de/Gasturbinen/VNT15-Turbo/vnt15-turbo.html
Turbo actuator Repair
http://www.jaguarforum.co.uk/f26/turbo-actuator-repair-44572.html
Interior Courtesy Light Replacement
http://www.jaguarforum.co.uk/f26/interior-courtesy-lighting-bulb-replacement-5124.html
http://www.mediafire.com/view/?qap74303wvixnze
Accessory Power Socket (Front) Behind Glovebox (with pictures)
http://www.jaguarforum.co.uk/f26/accessory-power-socket-behind-glovebox-28561-2.html
conversion of my fixed GSM phone to Bluetooth
http://www.sijones.com/Jaguar/GSM_to_Bluetooth_guide.pdf
Starter motor removal-diesel
http://www.jaguarforum.co.uk/f26/starter-motor-xtype-2-0-diesel-22796.html
How to Check for Sill Corrosion
http://www.jaguarforum.co.uk/f26/how-check-sill-corrosion-47388.html
Ian D
Administrator
Staff member
I Have Donated !
8,550
432
118
Hampshire
I have placed a new sticky thread with renewed links that sijones has kindly sorted out in x-type stickies.
It's called How to Guides for x-types: 2014 edition.
Rory
Administrator
Staff member
1,328
75
53
UK
I have got alot of these now working...
