1 - 13 of 13 Posts
I've had issues with hot starting, and was advised to have the ecu updated. The egr was already blanked off, and the garage said I should remove the blanking plate, clean the egr and manifold before doing it, which I did.
Whilst the starting improved, it didn't solve it, because after a few months the problem returned.
Another garage now says I should put the blanking plate back in. My ignorance is that I don't really understand why this might improve the situation
A supplementary ignorant area is would there be any benefit of cleaning the egr valve again while I'm at it?
cheers
cheers
from my experience a bad EGR causes cold start problems not hot start problems. try unplugging the egr, and see if it'll hot start.
if it makes no difference, try the same with the MAF,
See if there is a member near you with the mongoose/sdd who can do the software update, for the hot start stumble
have you done a leak off test on the injectors?
It's all up to date with the newest jag software, is this different? Thanks
No, if its on the latest its on the latest.
So that means that the egr valve would be fully open all the time? I'll experiment!
if you unplug the egr, then it'll be closed!
Discussion Starter · #9 ·
The latest update:
It's got the latest ems software.
Ive got the temperature up by replacing the oil filter thermostat.
I've blanked off the egr.
No real improvement in hot starting!
But logic tells me the problem is almost certainly that the cylinder internals are gummed up. That didnt happen overnight, so it wont go away overnight either. So in went a bottle of Wynns into the fuel, and after only 50 miles, its far better!!
Fingers crossed, its not a false dawn.
The latest update:
have you tried starting it with the MAF unplugged?
I'll certainly keep that up my sleeve, and try it next. What do you hope it will change?
i reckon it'll start hot no problems with it unplugged, because it defaults to a neutral map. If it does you can replace the MAF and it should fix the problem.
1 - 13 of 13 Posts
