Hi to all,
I have a 2000 XK8 which has been sitting on my dad's drive for at least 6 years, while during visits to him, I have replaced the gearbox oil pipes without dropping the gearbox out. This entailed removing the exhausts up to the manifold, throttle body, header tank and heater control valve with octopus pipes to get access.
While putting it back together, I have noticed strange behaviour in the instrument cluster, namely the instrument lights not working (except sometimes when they are not supposed to be on).
Also, with the battery connected, the minor cluster warning lights for oil pressure and battery voltage come on, and stay on, even with the key out of the ignition, the car locked from the outside and the alarm set. On one occasion under those circumstances, the instrument lights came on sometime later, and stayed on too, so I had to disconnect the battery to avoid possibly draining it flat overnight.
Just to add to my problems, occasionally, when reconnecting the battery, I get a fast clicking noise from the rev counter and speedo, as they bounce up and down slightly from their at rest states.
I have pulled every fuse and relay from all 5 fuse boxes, but no fuses are blown and no relays seem improperly connected or dirty, and show no signs of burning at the contacts.
I know relays can pack up without any outward signs of malfunction, but the instrument lights do work, although only when they shouldn't, but not when they should.
Last week I got the car started, but the rev counter showed no reading at all. The car is still up on plastic ramps so is not ready to move yet, but the speedo probably won't work either.
I know there are 3 ignition relays and an engine management relay, plus a body control module, so my questions are, has anyone had similar behaviour from their instruments and found the cure, or could anyone suggest what the cause could be?
Could it be anything to do with this thing in the pic? The black box centre of pic just in front of the rear engine bulkhead. I don't know what it is called, or what it does. Is it the ECU?
