I understand it may be a stupid question but, when this "beeping" is happening, are you reversing or just slowing down? (going forward)
I understand it may be a stupid question but, when this "beeping" is happening, are you reversing or just slowing down? (going forward)Hi everyone,
I got a 59' plate XF 3L V6 Luxury (automatic) yesterday. Beautiful car.
I'm not sure if I've got a fault or an annoying feature though...
When I go back down to 10MPH I am getting an internal beep from around the steering console area. It is quite loud and isn't linked (as far as I can tell) to the parking aid (which I've tried turning down).
Do they all do this? Or should I have it looked at? Is it something I can turn off?
Thank you!
Just slowing down. Any time I come down from above 10MPH to 10MPH I get the noise (going forwards).I understand it may be a stupid question but, when this "beeping" is happening, are you reversing or just slowing down? (going forward)
Thanks for the idea!Maybe it is related to something that operates at 10mph although why it should beep when you slow down to that speed I don't know.
On my 2013 car, drive away locking can be set at 5, 10 or 20mph. It can be adjusted in the touch screen. Maybe try altering this and/or enabling then disabling to see if it has any effect.
If you have blind spot monitor in your door mirrors this also operates at 10mph although I don't think the owner has any control over this.
I'm clutching at straws here but there must be a logical explanation.
As far as I can see, this is off. However, I'll try a spin now and see if maybe it's fundamentally got 10mph in its head from somewhere!Have you checked the ASL (auto speed limiter)?. I've never used it but clutching at more straws!
Gave this a try - still no luck though.As far as I can see, this is off. However, I'll try a spin now and see if maybe it's fundamentally got 10mph in its head from somewhere!
I'll mention this tomorrow. It's booked in at the place I bought it from. Fingers crossed it's just that as it sounds cheap haha!I used to get a similar beep in my old S-Type, turned out it was the SRS airbag system light had failed.
Ok - sorted it.I'll mention this tomorrow. It's booked in at the place I bought it from. Fingers crossed it's just that as it sounds cheap haha!
