321 - 340 of 437 Posts
For those who have hyper v which is built into windows 11, mongoose shows usb device as being inuse and can never connect over remote desktop (remotefx). But you can use virtualhere for free and simple to install to share the usb mongoose usb device from your host.
Does your SDD work? My network tests are ok, all calibration files are downloaded, 60Gb +, but when I click on recommendations and want to fix, it won't fix unless connects to internet / topix which is in green.. seems that despite downloading all files it won't work without internet connection to jag servers
Yes. See attached. I run v164.
Download latest version here, I'm using 164 but it's 3gb so can't really upload.
Then files below is a readme with instructions on how to sort your issue.
Only use on a virtual machine as may contain virus.
Yeah, I run everything in VM. Don't know what's going on with mine SDD (it used to work no problem), I have installed the latest version from jlr link few days ago and followed instructions. All calibration files downloaded (again) etc. Once I connect to my 2013 jag, find the issue / problem, click recommendations, want to execute, it stops be asking for internet connection and to topix despite have both :( I also deployed one on Win 10 pro v165 and older versions, same issue on few VMs and different internet connections (and it all used to work). Ah well, will figure out one day XD thank you for your help!
Did you run the offline1 login immediately then offline2?
