JAGUAR SDD (Symptom Driven Diagnostics)
ORIGNAL POST 29/05/2018
Uploaded JLR SDD 130 & 138 uploaded
UPDATE 27/05/2019
Have re-added my YouTube videos on second post
UPDATE 11/05/2019
Have reuploaded IDS 125 and SDD 138.
They are available from the Link at the bottom of this post.
UPDATE 19/12/2021
Have added SDD 160.4
Only tested to auto reading the Vin on my 2014 XF.
UPDATE 14/08/2023
Cleaned the text up little bit
YouTube Videos deleted regarding privacy concerns
UPDATE 12/03/2024
Further cleaned up text with reason they are VM and why they can not go online
UPDATE 12/03/2024 (2)
Added SDD 160 full +patch +engineering menu calculator (Native Install and UNTESTED!)
Keygen has a Virus, so would advise VM or dedicated SDD laptop install!
UPDATE 17/05/2024
Uploaded SDD 164 and Patch as a native install (UNTESTED)
(File is saying 163? As i have done this on my phone, its hard to investigate?)
Added picture of my software Engineer
Amber the Beagle
UPDATE 05/07/2024
Removed CCF Tools 4.6 as its passworded.
(Will add version when i can find one!)
Changed name of thread to JAGUAR SDD in VIRTUAL IMAGE
UPDATE 20/07/2024
I have added contributions from a member of the forum under New Files.
1. A modified virtual image of JLR SDD V130
2. Different key generators for engineering mode
3. A universal VESA video driver for use with Windows XP in virtual machines
4. CCF Tool 4. 6 (but without serial number)
UPDATE 23/01/2025
Added CCF Tools that doesn't need a password. This is provided as is and is a contribution from a member who provided the software above.
UPDATE 01/05/2025
Added Jaguar SDD 167 (TESTED) Native Install
UPDATE 07/05/2025
Added Jaguar Maps 2020 for Gen 2.1 InControl Touch (Need Keygen!)
Added Ghost Spectre Windows 11 (Light weight Windows 11, Choose Superlight, not Compact install )
UPDATE 12/05/2025
Removed link to my Drive for Operating systems.
Ghost Spectre link to his YouTube remains.
UPDATE 02/06/2025
Removed SDD 164 (Native)
No longer needed as SDD 167 works fine
Removed Mongoose driver.msi (doesn't seem to work?)
X64/x86 versions work fine
UPDATE 12/06/2025
Jaguar SDD 130 (Native) added
Untested
(This is not the version I made my original VM from)
Native install files and 9 RAR files.
What ever suits you best to download!
UPDATE 12/06/2025
Links updated and file paths changed!
(This is to break any off site links, as I often find obscure sites linking to my storage)
If you want to distribute in other locations, like other forums.
Then please host the files yourself, for any external sites.
These files will always be available here, without the need to be authorised for a download.
UPDATE 13/06/2025
Added J2534 Toolbox 3 Installer
UPDATE 23/09/2025
Added SDD 131 (Native) and IDS 118,119,125
Also the Tabman.Exe files mentioned in post #434 by Nerja
All untested as they have been uploaded using my phone!
I created these images to make it a little easer to get up and running with JLR SDD and have continued to host and share to the community for 7 years+.
The reason they are in Virtual Machines is that the older versions run older windows, but can be easily run on new OS's using Oracles VirtualBox.
(Windows, MacOS, Linux)
This is simply for future availability and keeping the install in a self contained environment. So it is easier and far quicker to reinstall, than if it was installed natively.
(If something goes wrong!)
As it is a VM, you only have to install VirtualBox on systems where native installs might be frowned upon like a works laptop for example.
Over the years I have seen these links appear on commercial sites selling products.
You should never pay for these images!
I will request if you download or use anything I supply!
You give a few pennies to animal charity.
I take no responsibility for any damage to equipment or car with use of this software!
The software is clean and only misuse or inexperience, will cause any issues.
I also in no way lay claim to this software as my own
Any copyright is held by their respective holders.
(I just made it easy to install)
Also a basic level of PC knowledge is advisable!
Also the software is what it is!
Its a powerful tool even without a Topix subscription.
Unfortunately some aspects will always be pay-walled behind that subscription.
That is something I can not or ever will be able to change!
Do not activate any kind of online connection in the virtual machine or native install.
It is Cracked/Hacked software!
While it is limited in some aspects, it is still a vital tool in fault finding and repair
Allowing it online, it will try to update itself to the latest version.
Overwriting what every method that was used to allow it to be cracked.
Then you will need to pay for a Topix subscription to continue it's use.
Pricing for a single model, ranges from £33p/h up to £1,192 per year (UK)
Link to Prices
Jaguar SDD LINK
Ghost Spectres YouTube
UPDATE 27/05/2019
UPDATE 11/05/2019
UPDATE 19/12/2021
UPDATE 14/08/2023
UPDATE 12/03/2024
UPDATE 17/05/2024
Amber the Beagle
UPDATE 05/07/2024
UPDATE 20/07/2024
UPDATE 23/01/2025
UPDATE 01/05/2025
UPDATE 07/05/2025
UPDATE 12/05/2025
UPDATE 02/06/2025
UPDATE 12/06/2025
Untested
UPDATE 12/06/2025
UPDATE 13/06/2025
UPDATE 23/09/2025
Link to Prices
Jaguar SDD LINK
