ck_uk
I did this job on mine, I dug out the old thread - see below (if it helps at all)
I found it to be a real "wish I hadn't begun this" task but when i'd finished it, I was well chuffed.
After I'd located where the starter was actually located, I went thru the right hand side (removed the battery for easier access) to access the USAINs - long reach spanners are the order of the day, dropping the starter out from underneath as I remember.
Good luck with doing this - don't give up if you get stuck. There are countless brilliant minds on this forum!
http://www.jaguarforum.co.uk/f26/starter-motor-38695.html
