maxispeed 275
A little bit of advice needed do you need any special tools to fit new front brake pads? Thanks in advance
Thank you for your super fast reply Stay SafeNo special tools required.
It's very easy to do. Check the videos on YouTube
Thank you for the info last night started to do the brakes and you can guess what no 9 mm hex so have to try and get one from somewereMine needed a 9mm hex. Which isn't special unless your kit goes 5, 6, 7, 8, 10.
Make sure you have one if needed.
Cheers for your input and yes out 60/70 allan keys and hex keys no 9 mmYes, you need a 9 mm hex driver for the front brake caliper slide pins and as noted they are rarely included in hex driver sets.
Plenty on Fleabay, Amazon etc though.
The first time I did the brakes on my old 2010 XFS I took the car to my favourite exhaust shop which had an auto mechanic and brake specialist next door and even they didn't have a 9 mm hex driver!
You also need a 7 mm hex driver for the rear brake caliper pins but they are much more commonly included in sets.
