Jaguar XJ40 GUIDE to: Replacing the Heater Controls
JSeaman
178
Re: GUIDE : Replacing the heater controls
Step 29 - Replace the ribbon cables and clips the boards back into place before joining the two halves of the box back together
Step 30 - Slide the control unit back into the centre console
Step 31 - Ensuring the panel is aligned properly, refit the 4 Philips screws
JSeaman
178
Step 32 - Reconnect the multiplug, this is just a push-fit and should click into place
Step 33 - Again, ensure the gearstick is out of the way
Step 34 - Slide the assembly back into place, be careful you don't stress the tabs, especially the top two as shown in the picture
JSeaman
178
Step 35 - Refit the 6 screws that hold the panel in
Step 36 - Align the wooden trim with the front of the dash then ensure the threaded bars slide into the holes before pressing the trim into place
JSeaman
178
Step 37 - Refit the two nylon wingnuts
Step 38 - Slide the small black plastic divider trim in
Step 39 - Reconnect the ash tray wiring then drop the unit into place
JSeaman
178
Step 40 - Refit the two Philips screws in the storage compartment
Step 41 - Clip in the black surround, note the clip arrangement that holds it in place as it pushes down
Step 42 - The leather surround is just metal spring clips which push down around the gearstick
Step 43 - Back to 'Park' then give your new heater control panel a test
neil.mitch
25
1
Step 26 - Use solvent cleaner to remove any deposits and then re-touch all the solder joints
Step 27 - Once you have finished reworking the PCB, place it back into the enclosure
Step 28 - Refit the small Philips screw through the plastic surround
Hi. Have you pictures showing where the vacuum pipe goes please. The one that goes to the right hand fan blower box to work the air flap?
Rgds
Neil
