Hi. Checked my washer reservoir yesterday and it took several pints to fill it to the top of the bottle. Today I noticed two small puddles under the car - one directly under the number plate, the other underneath the off side headlamp washer. I refilled it and it took about four or five pints again. I checked, and the water started dripping out as soon as I had topped it up. I've only had the car a couple of months and never bothered checking the level as I know there is a message centre warning if it drops below a certain level. I know the dealer resprayed some front end stone chip damage before the car was delivered, so maybe they didn't refit the hoses properly afterwards, or perhaps one of the headlamp
washers is leaking. It's odd that it didn't display the low fluid warning long before now, unless it stops leaking when the fluid reaches a certain level. I assume this will be covered by the warranty, but I'd be grateful to hear from anyone who has had the same problem, or has heard of it happening before. Many thanks!
