1 - 20 of 20 Posts
Just to say I'm very happy with the LED upgrades. Main, dipped, side and fogs (driving lamps) all done. Gives a very bright, white light. Bit of a pain to fit as I had to remove the front bumper, (this is necessary on some models). Well worth the effort though!
How far does the beam throw - in terms of feet?
Discussion Starter · #3 · (Edited)
I would say roughly the same distance as the original bulbs on dipped, only far whiter. Main beam seems to go on forever! Fogs (driving lamps) don't offer a great deal of illumination, more like DRL's.
They do look good.
Is your front suspension a bit high?
Discussion Starter · #5 · (Edited)
Haha, you're not the first to mention that! It looks high as I had just lowered the car off the axle stands, the shocks and springs were still a bit extended. It's sitting normally now.
Wheel Tire Car Vehicle Cloud
Ah, much better!
Smart looking motor you got there mate :)
Thanks - I didn't know you could get LED bulbs for car headlights but it makes sense when you think about it. Which bulbs did you use and is it an easy fit - I mean any different to the normal hassle? I had a quick look for bulbs and all the ones I found include a heat sink at the back so presumably the cover does not fit on and what about the bulb retaining clip?. I also presume you just clip it onto the 12V headlight supply? There are also some reports of CANBUS errors - is this a current measurement thing as the headlight unit has no sensors built in? Final thought - was is the legality of this upgrade?
They do look good but for me its more important that I can see better. You say that the light output (throw) isn't that much better than stock; for me that's a problem as my eyes are 62 years old. :)
Discussion Starter · #10 ·
Hi, actually I said the fog lights didn't give off an improved light, they just look good. The dipped beam has the same distance range as the originals, only much whiter. I do find them a great improvement on the originals. The main beam is fantastic, great distance coverage and fantastic white illumination. BTW, I'm 63!
Discussion Starter · #11 ·
Hi, can't find the link to the ones I bought but I will post a link to similar ones. Fitting them is no different to fitting normal bulbs, however I had to use a small cable tie to keep the bulb retaining clips in place. The rear covers still fit over the fan units on the LED bulbs, it is advisable to drill a few small holes in the covers to aid heat dispersion. No canbus errors as no sensors. As for the legality I have read of many people who have them fitted have had no problems with MOT test.
https://www.ebay.co.uk/itm/2XCREE-N...059447&hash=item2832ac81e9:g:T2AAAOSw~y9ZArlv
Thank you this information; it will help many of us that decide to go down this route.
Looks very nice, I might go this route once you've tested them for a while!
200 w per lamp is a lot of extra load though.
Surely LED's don't run at 200 watts. I reckon that refers to the equivalent output of a tungsten halogen lamp.
I wasnt aware that you could get LED headlight and High beam bulbs.
Mine has the Xenon headlights but all the other bulbs are (were) normal bulbs until i replaced the sidelights and indicators with a very nice result, especially as the sidelight colour now matches the dip perfectly. Main beam i replaced with some 150% brighter jobs from Hellfrauds (again, great!)
I plan on replacing all the other bulbs on the car with LED's once i have found a buyer for my Kidneys.
You can get 200w leds, but they require a serious amount of cooling, and they are pretty large, even a 50w led cob chip requires a fairly large heatsink, most of the Chinese bulbs give a watt equivalent as you say, though most are overrated.
Led technology is getting better but from what I've seen and tried I'll stick to HID, I had 80w Cree fog lights and the lights while bright were not giving a good spread of light for use in fog, too much dispersed light, switched to 55w hid and the low wide spread of light is back, just brighter.
Its bad enough to lose any kind (Halogen or HID) of headlight while driving -- especially in transit. But to lose an LED that certainly isn't readily available at your local gear-shop - you'd better carry a couple spares in the trunk and at home for emergency.
True, and while leds have one of the longest service lives of lights they don't when overdriven or overheated.
1 - 20 of 20 Posts
