Lower Pulley, Tensioner, Belt and Shield 2.2
Axat101
Active member
I Have Donated !
203
86
38
Axat, south of France
I have read the sticky about this subject with interest. i was unsure whether to post my question there or here and have gone for here. Don't all black ball me at once.
I intend to keep my car (2009 Auto estate 2.2) and am slowly going through the car. Tomorrow the auto box fluid is being changed, the turbo cleaned and the turbo actuator being replaced.
I am aware that many X-Type deisels have a problem with the title of this thread. I have zero noise and no current problems. I have read elsewhere on this forum that the later cars like mine are less prown to a problem with the tensioner as it was improved at the factory.
My question is A) is that correct? and B) if not as the original link in the thread/sticky no longer works can any kind soul place a link to the uprated part as I can find hundreds of standard parts on eBay but not the improved part.
Many thanks
Paul
Billy2Jags
Senior member
5,760
169
98
Midlands, UK
If it ain't broke, don't fix it.
The only thing I would suggest is to fit an over running pulley to the alternator to give the tensioner and crank pulley an easier life.
If you need a pulley, I can supply but would need to check postage costs to France......
Euan Tausney
Senior member
2,736
134
78
Clydebank, Glasgow
Hello again, the later cars had no modifications to the belt tensioner or bottom crank pulley as you suggest. The Kit Jaguar supplied to fix this problem had a beefed up crank pulley, mine did not have this fitted, and was one of the last ones made, as was yours. The solution that most go for is an OAP fitted to the alternator(Overrunning Alternator Pulley) which takes the load of the tensioner & pulley, preventing belt slap.
Whiskery
Active member
I Have Donated !
111
33
28
Swansea
Euan Tausney
Senior member
2,736
134
78
Clydebank, Glasgow
nicam49
Active member
231
32
28
Leicestershire UK
