I had some fun with lugnuts the other day. When I purchased my car a few months back, I had my rims refinished. When they put the rims back on, they over torqued the lugnuts on one of the rims and actually rounded off two of them I had to fight to get the other three off but had no chance with the other two. I knew I would have to replace at least those two so I ordered a new set. I took it to the local tire place and he didn't want to mess with it. He said there was a good chance he would scar up the rim taking it off and didn't want to try.
So I bought a set of bolt extractors. I tapped on the the 19 socket and used a half inch breaker bar with a 3/8 adapter. And guess what? The adapter snapped. It was very tight. Under warranty, I had it replaced and guess what? Snapped again. I then ordered a Gearwrench 19 3/4 bolt extractor that is 3 1/4 inch long with a nut fitting on the end. I then used my 18 inch crescent wrench(weighs a half a ton). I pounded on the socket and with a mighty force, the lugnut came loose. I then repeated that with the second lugnut and same result. I figured that wrench was not going to fail and Gearwrench socket certainly was not going to fail (i don't have an airgun). I figured the worst thing that would happen is the outer cap would get ripped off exposing the under nut. If that happened, I would deal with it but I guess I got lucky. I have seen videos of mechanics drilling out the studs which would take hours. If this happens to you in the future, this procedure will work. The socket stuck out far enough that the rim was not in danger.
