Well, an interesting day exploring the XJ.
First up, jacking the bugger up. I've seen the official jacking point info, and as I've seen on various forum threads, the jacking and axle stand points are too close together so you can get a stand in place because the jack is in the way. Has anyone got an alternative place for axle stands at the front? I had to rely on trolley jack alone, with a wheel under the sill, and making sure I didn't go underneath! If I can't figure that out, then it's going to be tricky to work on it.
I noticed the undertrays are a bit damaged and numerous structural zip ties are in place.
Anyway, I'm guessing you shouldn't be able to move the banana arms much by hand. These are properly loose and move far too easily. All the other bushes had only minor deflection from a large screwdriver, so these are definitely the problem. Time to get some powerflex ordered.
Next up was the dechroming of the mirrors. I got the new mirror prepped and got a couple of coats of paint on. While I waited for it to dry I popped the chrome cap off the other and cleaned up the sticky pad residue. That's when I realised the mirrors were different shapes. Like the idiot I am, I didn't think to check first, instead trusting the ebay listing. To be fair, they're quite similar but different enough that they just won't fit. I reckon it came from an F Type. I've ordered another and this one looks OK! Too late to return the other, so will chuck it back on ebay.
I then popped the bonnet. I was told it was recently serviced but the state of the air filter told me otherwise. It was at that point that I spotted another problem. The Y pipe from the air box to the MAFs isn't actually attached to the air box. The end of the pipe has broken loose. There's a bit still screwed to the air box but it's come away at what looks like a seam about a centimetre up the pipe. Looks like it's been bodged with sealant in the past. That means there's a small gap letting unfiltered air in. Not ideal, and needs a repair ASAP. I've ordered some plastic weld epoxy so hopefully that'll sort it. It's all PA6 nylon so not a lot sticks to it.
Will get a full service done on it as soon as I can.
The more I look, the more it's clear that it's not been well looked after! Slightly concerning, but it's kind of expected when buying right near the bottom of the market. I'm still reasonably upbeat about it all though and I'll get most of it fixed in time. Hopefully it won't bankrupt me in the process.
