1 - 3 of 3 Posts
I could have sworn I started a thread for this years ago but damned if I can find it...
For pretty much as long as I've had the car (I think) the driver's side wing mirror tilt/turn recall when using the memory positions for seats/mirrors/steering column hasn't worked. Instead of going to the position it was in when the settings were stored, it points either straight up or straight down and has to be set manually.
I know the motor has position sensors in it so I changed that recently but it still isn't working right, points right up or down. Pretty sure I can rule out the battery as it was doing it even after changing to an AGM type and will do this even when the car's had a good long run so the battery will be charged.
What's next to try, driver's door module?
· Administrator
Haven’t you tried reprogramming the modules? That may sort it instead of replacing more items. Those door modules are very expensive new.
1 - 3 of 3 Posts
