It's been a while since I last posted an update here so thought I should take the opportunity. The hopefully final transfer box drain modification iteration which I completed a few weeks has held up wonderfully with no visible signs of leaking around the drain or hose inlet, not that I doubted my workmanship
. The job of refilling was such a simple job now being done up at the engine bay and only took a few minutes of injecting the oil into the hose. It folds away neatly behind the battery box as I wanted to keep some extra length to make the refilling job easier.
On Friday I stripped out the rear seats as I was driving down to my sisters at Loch Lomond to pick up the Premium Sound audio components and other interior bits that I had couriered up from London and needed the extra room that it would grant me. There was a ÂŁ300 difference in it being delivered to my sisters or taken the extra 100 miles up the A9 hence for the trip which saved me a couple of hundred minus the fuel. The car remains a two seater for the moment which I find quite amusing, only because I didn't find the time today to get the seats bolted back in, although the interior modifications may just mean that they stay out for a while longer, unpractical though it is.
I'm still in the process of trying to source the connectors required for the amplifier, rear tweeters and under the dash for the piggyback loom. Every breaker I've emailed with an X-Type in stock clearly having premium sound won't entertain my request... for the life of me I don't understand why, perhaps too little a return for the work of a couple of cuts with a pair of pliers.
