NON RIESCO A SPEGNERE ARIA CONDIZIONATA XK 2007
84 views 4 replies 2 participants last post by  lacovaradesigner
Hi everyone, I recently bought a 2007 xk na which I'm very happy with, I only have two problems, I can't turn off the air conditioning, it always goes to idle, then I have the steering wheel that makes a kind of squeak at low speeds, I hope someone can help me, in the meantime thank you and greetings.
#2 ·
Are you turning the a/c off using the "Climate" button in the central digital display? You can't turn it off using the physical dashboard controls.
Is the squeak from the steering wheel in the passenger compartment. Does it happen only when turning the wheel from one side to the other. It sounds like a simple binding problem within the mechanism so you will probably need to remove the wheel to investigate further.
Richard
