Marko the O2's are like spark plugs, they're in a harsh environment and do wear out eventually, your's is a classic example, posts a code after a long run coming off gas.
Just buy a code reader (if you haven't already I'd recommend a memoscan 581, ebay £50 or so) and clear the code. If it becomes a permanent warning then buy the oem unit and replace.
Cold engine tap, first off - drop the s/c belt, see if this removes the tap - then it's look into the tensioner and idler bearings and s/c and belt. If not, then it's time to look further. The May 2002's a well clear of the plastic tensioners, indeed they have the latest and greatest 4.0s/c units with all metal timing parts and morse style silent primary chains, so it won't be a timing issue.
For the LPG - get the best you can afford, I've heard Remarno? Italian kits are the best - also talk to go-lpg these lads are the no.1 in fitting LPG to Jaguar's and always advertise them in the Jaguar Enthusiasts Club magazine, if there's anyone who can tell you about VSR it's them.
How's the de-roof car? finished?
