P1638 and P1699 problem on x type 2.0D 2003.help pls
4.1K views 3 replies 2 participants last post by  jikar4e
hi everybody.i had a post some time ago with my problem.the engine light is on,the brake light also and the abs.the cruise not working,wipers,break lights etc.after the scan i got the codes P1638 and P1699.they are both connected with a CAN network.after many hours of tests finally i found that there is an open CAN+circuit.the question is how to find the defect.i now it can be basically everything but if anyone experience this problem i'll really appreciate any help.all the fuses are OK.thank's
#2 ·
According to my data, these codes indicate the problem is between the Instrument Panel and the Engine Control Module (P1638) and/or the Instrument Panel and the Air Conditioning Control Module. Chances are it's a bad connection at one of those modules. I would clean and check the two plug-in connectors to the Instrument Cluster first as it's common to both codes. Both plugs are White 26 way - don't get them mixed up!! The CAN wires are the Green and Yellow ones next to each other in the plug nearest the centre of the panel.
