P1647 Fault code
1 reading
26K views 15 replies 9 participants last post by  ldare2000
Hi Everyone.
Just acquired my first Jag and still getting used to it. I think it was love at first sight and it got even better after I sat in her.
Anyway it has an engine warning light ON, the small garage dealer that I bought it from said that it was a lambda sensor. He said it had been replaced but the fault code needed resetting.
I bought a code reader & it came up with
P1000 - OBD system readiness test not complete. I believe is not a problem
P1647 - Linear 02 sensor control chip ( bank 2)
Codes were reset but the warning light returned pretty quickly.
I had a look under the bonnet & found two O2 sensors (one per side) at the back of the engine visible from the top. I believe there are another two O2 sensors somewhere else.
Could anyone tell me the location of the faulty sensor, how to test a sensor, a supplier for the sensor & how easy it is to replace.
Happy motoring
#5 ·
Not had chance to look at mine yet.
Will probably try to test the sensors in position (Resistance, Open/Closed circuit I quess)
Does anyone know what typical readings I can expect.
Kaled00 did you change just the sensor you thought was faulty.
If its still showing the same error on the engine diagnostics maybe its a fault in the wiring loom or the control box that th sensor connects to??
Need some time & warm weather to get me motivated into looking at mine.
#8 ·
Replaced lambda (n/s upstream) with universal one ÂŁ35..........this still came up with the same fault code,(p16476 -open or short circuit on n/s upstream) :( :( i started thinking there could be a wireing fault but bit the bullet and bought a genuine jag lambda....hey presto the nigh on ÂŁ100 cured it !!!! :D
#9 ·
Finally got round to sorting the oxygen sensor out.
Sounds like I went down the same road as v9djd. I bought a new sensor from ebay (ÂŁ20). It was supposed to be compatable bit it did need the connector changing.
New sensor
2 white wires reading 8.2 ohms, 1 black wire o/c to everything, 1 grey wire 0.3 ohms to sensor body.
Old faulty sensor
2 black wires, 1 white wire, 1 blue wire. O/C on everything
Fitted the ebay sensor & it did not clear the fault.
Bought a sensor from the jaguar dealer (ÂŁ85).
Wires as old sensor except 2 black wires read 1.2 ohms.
The new sensor from jaguar fitted, error codes reset & no warning light.
Before fitting the sensor The engine revs would fluctuate up & down by about 200 mainly for the first 10 mins of driving. Looks like that problem went away after fitting working sensor.
Now to tackle the other fault "Passenger air bag warning light" permanantly on. I will try reseating the connectors under the passenger seat & may be back on here if that does not cure it.
#10 ·
thanks alot Rough_cut_gem done roughly what u said and tested the censor had no condinunity tested the other one on the car and has 1.2 ohms across the black wires so guess the sensors knackered will get a new one tommorow as i have the p1647 fault code and failed the mot today as imissions were at 1.900 and should be lower than 0.500 and read some where that when a lamard sensor goes the ecu reads it as running lean and tries to increase it hence the immisions to high some one please correct me if im wrong thanks alot
#12 ·
I was also reading somewhere that Jag actually recommend that these be changed at 100,000 miles anyway. Mine has done 86,000, so not too far away.
The article went on to say that with new sensors, one could expect an uplift of 10-15% on MPG. I'm hoping this is true as this will recoup the cost of the work after about 12 months for me!!
#13 ·
I was told the same by my Indy. He went on to say that eventually it would knacker the CAT, so it's ÂŁ100 well spent, when compared to the cost of a new CAT.
#14 ·
Changing the really old type was almost mandatory LOL but with the very new kind in the facelift S-Type I'm not sure there's really any good data. Can't hurt, apart from the cost, though!
Possibly this article: http://www.autotap.com/techlibrary/repl ... enance.asp although it doesn't actually cover the main ones in the facelift - it only covers the downstream type.
(The upstreams control fuelling and are of the linear aka wideband or AFR type.)
