Brought a a pair of Pagid front discs and a set of pads to fit to my wife's Audi TT this W/E. What is strange about the discs is that the surfaces are covered in sort of silver paint - the instructions say this is a protective coat that should not be removed before fitting. Assume that after the new discs and pads are installed the protective layer comes off as the the brakes are applied and the usual metal surface will be revealed - bit unusual though - anyone had experience of fitting these sort of discs?
