There are a number of rear park modules depending on your cars VIN range (whenever querying a part always add your cars MY or better still last 6 of your VIN AND add it it to your sig to save being asked and saves time)
I retrofitted a Jag reverse park kit when I had my 2002 X Type and ended up with the wrong module (different connectors and distance between the mounting holes).Eventually got a new one (£50 at the time) and it was just plug and play.
None of the numbers you list show the short Jaguar part code most often used which will start C2Sxxxxx or C2Cxxxx
If you can get it from the dealer by giving them the long Jaguar part number (4X43-15K866-BG) which they can cross reference you can use google to see if any used or others for sale.Only the short part numbers are shown on my copy of the EPC, (easier to google and look up with dealers and online)
It sounds (no pun intended) like you have the wrong module if only the rears are working
