My front and rear parking sensors have stopped working , asked a mechanic to check out,he replace a sensor he thought was faulty, still not working, he suggests fitting a replacement module which can be expensive esp if this is not the problem, also says it may have to be programmed to suit car, is there any way the module can be repaired or tested to see if that is the problem, 2009 x type ??
Thanks for any info
Thanks for any info
