Jack up the drivers rear wheel and support on an axle stand or ramps if you have some. Next to the rear wheel underneath the car you will see the fuel filter. Dead easy to remove the pipes just press the tabs in on the clip and pull off, be careful and get a jug or something to catch the petrol which will still be in the filter. Light up a ***. (joke!!
) Undo the 8 or 10mm bolt which holds the thing up there, then slide it out of the bracket.
Refit new filter making sure its the right way (should be arrowed for flow) tighten up bolt, refit pipes making sure they click back onto the filter.
Give your key a couple of on off's to prime and fill up the filter. Job done, wash hands and put the kettle on. Send kids up to bed, prepare the missus for an early night
