quick tire size question
174 Views 8 Replies 6 Participants Last post by  TheBoy
what would be the difference if any between these size specs:
245/40R20 Y
245/40ZR20 99Y
specifically are these 2 essentially the same/interchangeable:
https://www.amazon.com/gp/product/B00KTEAW5A/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B01KKWU016/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
1 - 9 of 9 Posts
The ZR 99Y tyre has a higher top speed rating.
Also if I’m right, the 99Y is structured for bigger cars
99 is the load rating, Y is the speed rating.
You must never go below either number as stated in your user manual (irrespective of the fact you may never exceed 50mph), but both can be exceeded.
I had a feeling the x351 had a load rating of 102, or was that just the rears?
Reactions: 2
US spec cars may have different ratings, hence needing to check your glovebox manual.
Reactions: 1
Yep 99 load rating on the front, 102 on the rear
Y rated to 186+ mph
Reactions: 1
Y rated to 186+ mph
See, my memory does half work. Ish.
Reactions: 2
1 - 9 of 9 Posts
