Rear brake discs and pads
philayl1
Senior member
1,862
56
53
Wirral, Merseyside
The wheel nuts keep the disc attached, although there might be a couple of retaining washers on the disc but you can spin these off. Phil
philayl1
Senior member
1,862
56
53
Wirral, Merseyside
Have a look here it might help, this is the rears being changed. Phil
Neilr
Super Moderator
Staff member
I Have Donated !
5,797
423
118
Germany
Most single-piece brake discs just locate on the wheel studs if you have them like we do on current Jaguars. Jaguar supply a couple of toothed-washers which are spun onto one or more studs to hold the disc more or less in place as you bolt everything up. Some disc have a couple of small screws instead, especially those that fit over hubs without studs.
OzJagXFS
Well-known member
1,216
28
43
Adelaide South Australia
On most modern Jag discs there are two small retaining washers, one on each of two of the five wheel studs.
They are there purely to hold the disc in place before you mount the wheel and they are not essential.
They can be a bit pesky to remove or replace as they are thin and fragile and you need to lever a couple of tangs up to get them off, then use a screwdriver to "knock" rotate the washers off.
They can be a trap for young players trying to remove a disc as they are not obvious at first glance.
maxispeed 275
80
9
8
northumber
Cheers for your input i got one side done last night but really struggled getting that big nut off in the middle then when i got it off thought damn that is the drive shaft nut and i didn't need to take it off them 2 little washers i got them off and didn't replace them so to crack on with the other side later today. Thanks again. Ray
Phil F
Active member
732
55
38
Kent the pothole capital of the world
Make sure the hub/drive shaft nut is done up to spec and add a drop of threaad lock to be on the safe side.
NM_OLD
Senior member
2,313
1,389
128
Oldham
