1 - 4 of 4 Posts
On startup now for the last few weeks I've been getting a continuous beep emanating from the rear of the car somewhere. This din eventually stops after a while, but not before causing intense irritation! I understand from this forum that this noise likely is a symptom of a problem with the rear parking sensor(s). (Please do correct me if I'm wrong though!) I'm not minded to fix the problem just yet, partly because I don't normally rely on these sensors, but is there any way I can just stop this beep from happening in the meantime, even if it entails disabling the sensors somehow? Thanks.
Try unplugging the module in the spare wheel well.
Always good to know that lives have been saved :-D
1 - 4 of 4 Posts
