Is there anything else I need to take off before it will come out? Doesn't seem to want to budge and I don't want to force it in case I break the glass
Thanks for the reply.
Does it look like I've removed everything necessary to be able to push it through (if it wasn't seized). If so I'll use mole grips and try to wiggle it out.
Not to worry - as per the picture above everything is off that needs to be.
I gripped it with some mole grips and turned it slowly while tapping it and it came out. Cleaned everything out and stuck on some teflon grease, reassembled and now working perfectly.
I'm not sure but try and turn the wiper with the window open. Mine wouldn't move at all. After greasing it although there's a little bit of resistance it moves freely.
If yours is hard to turn then it'll be worth doing this
Jaguar Forum
