Hi everyone,
I have a 85 XJ-S with metallic paint and I am rectifying all of the faults the previous owner was oblivious to.
Having taken back some of the trim, I've found some rust spots which are not normally visible that I'd like to address before putting the trim back.
My plan is as follows:
- Carefully grind out the surface rust using a wire wheel on a Dremel.
- Apply jenolite converter over the area to neutralise any oxidation the Dremel can't get to.
- Prime the area (see below question)
- Paint & clear coat.
- U-Pol 8
- Red Oxide
- Expoxy primer
