1 - 11 of 11 Posts
I replaced the shocks on my 2.0d, and the difference before and after is out of this world, literally.
My car is now about 195000 Km, shocks were never changed (stupid, I know, but I just didn't thing about it).
Before I really had trouble on highway while passing trucks at high speed, the wind would shake the car a lot. Now, I don't feel the truck *at all*. I pass them with high speed, and it is like they are not there!
Accelerating or braking made the nose dive. Now that doesn't happen at all.
Tire wear was significant. I am pretty sure now that bad shocks destroyed two sets of tires.
After installing new shocks, the car is absolutely calm and solid. A lot of road vibration just went away! I feel like I am driving a solid granite brick.
These are the shocks I got installed (I also installed the strut bearings):
BILSTEIN - B4 OE Replacement - FRONT - 22-053596
BILSTEIN - B4 OE Replacement - REAR - 24-064927
SACHS - SACHS 801043
For precise shocks (there are many models for X-Types: sedan, shooting brake, standard, sport, performance upgrade..) check here:
http://web1.carparts-cat.com/defaul...8004&12=101&52=1&30=56&1250=1&1230=9997&1231=
Did you change all four?
Also, If anyone is interested, cost of shocks and Sachs bearings was 320 EUR.
I'm thinking of changing mine, are these the same spec as OEM?
These are items that are often overlooked. Only attended to or replaced if spring snapped , leaking shocks etc.
My workhorse Mondeo ST Tdci broke a few springs over the years , I just bought another leg off eBay , fitted and away it went again.
A few years back I found a full set of front and rear springs and shocks , Sachs / Monroe , cannot remember now , on eBay Germany.
I think they were around £300 delivered from memory , put them all together ( came with Mayle top bearing caps as well )
After fitting these one weekend when the enthusiasm arrived , the difference was amazing and stability improved greatly as you have seen.
Discussion Starter · #8 ·
You are completely right about it. Difference in stability is dramatic. The funny part is that I checked the shock and they were rated as 70-80% good, the same as the brand new ones are tested. All this on local MOT test.
I got used to new shocks tho, the ride is fantastic. Rarely is some car more comfortable than my X-Type.
i was thinking of getting Blistein B6 all round for mine, B6 are a bit firmer than the B4, and they are a monotube, where as the B4 are twin tube.
Thanks,
I have found the following part numbers for my car with the sport suspension
B4 OE Replacement - FRONT 22-053602
B4 OE Replacement - REAR 24-062657
What are the recommend springs?
You definitely need the Mono Tube if you are changing. Bigger internal piston means better damping control.
1 - 11 of 11 Posts
