Replacement Cylinder Head Temp Sensor
576 Views 1 Reply 2 Participants Last post by  04str
Dear All,
Hope you are all well - I have recently replaced my Cylinder Temp Sensor as I noticed it had been damaged by the Jaguar engine bay cover.
Do you need todo anything special once its replaced to make sure that the ECU knows it works ?
A related issue is that when I disconnect the temp sensor the fan goes on full as if the engine is super hot. Heres the odd part - If I disconnect and switch off and on the gear changes are a lot smoother.
The next day / over night the gear changes become more erratic.
The gear box has been recently refurbished.
Thanks a million.
M
1 - 2 of 2 Posts
Stop messing, it's a computer.
It'll be fine if fixed and you let it be.
1 - 2 of 2 Posts
