Rough idling
157 Views 5 Replies 2 Participants Last post by  Bruyere
Hi, my 1997 XK8 drives fine, but when idling the engine is a bit rough and shaky.
I tried the following:
-replaced both camcover and all the sparkplug seals, there was some oil in the sparkplug holes
-replaced the sparkplugs
-replaced all the coils
-replace air mass meter (with used one)
-new air filter
-cleaned the trottle body
All of the above gives no improvement.
Any sugestions what else I can try??
Note: at the moment I can not connect an OBD scanner, the connection plug is dammaged, have to fix that first
Also, the chaines and tensioners have been replaced about 40k km ago.
1 - 6 of 6 Posts
You really need to get that OBD port repaired first. It could be a dirty fuel injector or an air leak but that is just guesswork.
Reactions: 1
Ok, will tackle that first! Thanks
Reactions: 1
Ok, looks like de OBD poort is working again. Got a few codes but doubt this has enything to do with the rough idling.
P1798, P0790, U1260 and U1041.
The first 2 appear to be transmission related and this may help on the ‘U’ codes; True meaning of the U1260 and U1261 codes? - Jaguar Forums - Jaguar Enthusiasts Forum
Thanks for the link. The TCM module have been replaced not so long ago, and last week I have removed the dashboard for some checks. Perhaps that is the reason for these codes. Have cleared them now, see if they come back.
Reactions: 1
1 - 6 of 6 Posts
