1 - 11 of 11 Posts
What is the best option when it comes to servicing? Is there a service plan offered by Jaguar? Im at 122k and need it done. Thanks
To be honest, I would always look for a good Indy. I've done that for my Jags and Bentley GT. Google your area and then look for reviews.
I'm sure there must be one and they are usually a lot cheaper too.
I tend to use the £199 fixed price basic service from my local main dealer, for convience really, yes it is overpriced. Anything else, I sometimes travel to the Jag Specialist in Doncaster, or DIY.
Discussion Starter · #8 ·
Thanks all for the replies. I have full service jag history so want to keep the stamps up although i understand the other side of doing it yourself knowing its how you want it. So Jag do offer a fixed price service?
Most main dealers offered a fixed price service 'menu' for jobs like routine service, brake disc and pad replacement, etc., for cars over 4 years old. However, I heard rumours that this had recently been discontinued by Jaguar. Not sure if this is actually the case but will find out soon as I am going to put mine in for new discs and pads on the rear. (I'd do it myself except that my drive is on a slope, so unsafe to just chock the front wheels while on axle stands to do it.)
Discussion Starter · #10 ·
Im in 2 minds abouts forking out £330 for a B service when i know all im getting is fresh oil and filters. I can do it all myself. What oil grade should be used? Fully synth 5w20? Also how do you reset the service reminder? Thanks everyone
The specified oil is 5w30.
If it's a petrol engine then you want an oil that complies with Ford M2C-913-B, (or -C, or -D, I think they're up to D now).
If it's a diesel then you want one that complies with Ford M2C-934-B (an ACEA C1 [low SAPS] oil). In the owner's handbook it specifies 913-B for diesels, but the spec quietly changed from 913-B to 934-B sometime between '08 and '12 (ie it became 934-B in the 2012 Vehicle Specs booklet)
1 - 11 of 11 Posts
