1 - 3 of 3 Posts
Hi all,
I'm about to do the servicing (oil, oil filter, air filter, polen filter, fuel filter) and any links are much appreciated (I was thinking to go with this oil: Total Quartz Energy 9000 0W-30 Motor Oil) for the other components.
I think I need 7L for oil? Any other suggestions please? maybe Castrol Magnatec Stop-Start 5W-30 A5 ?
Also, any ideas how to replace my XF 2008 3.0 V6 Petrol fuel filter? is it DIY?
Thanks in advance!
L.E. I was able to find this link: http://www.jaginfo.org/showthread.php?8578-D-I-Y-Service/page2 - is it the same vor petrol models?
I have also found this:
So long as it meets Jag specs, any fully synthetic oil should be fine. Most online suppliers give a list. I used Millers XF from opie oils which is good quality and good value but mines a diesel so your oil will be different. At least you don’t have to worry about the C1 low ash bit!
as for the video -diesel issue by the looks of it, to that my S has ever missed a beat.
Discussion Starter · #3 · (Edited)
thanks a lot jberks , totally agree. I had a quick chat with opie guys yesterday, as I was curious about a price difference between those 2. Apart the fact that castrol magnatec meets the Ford 913 latest specs, and XTR uses old specs, no other differences.
Regarding fuel filter, I had a look yesterday under my bonnet, there's no filter as in the video. I think it's located somewhere in front of left front wheel?
L.E.
I've decided to go with Fuchs TITAN Supersyn F Eco-DT 5w-30 Fully Synthetic Engine Oil
Fuchs TITAN Supersyn F Eco-DT SAE 5W-30 is a highly energy conserving multigrade passenger car engine oil suitable for Ford diesel and gasoline engines. The most up to date technology of TITAN Supersyn F EcoDT SAE 5W-30 is absolutely beneficial for current engine technology. TITAN Supersyn F Eco-DT SAE 5W-30 provides advantages in economy, durabilty and exhaust gas emissions. TITAN Supersyn F EcoDT SAE 5W-30 affords excellent durability for long life performance, wear protection and cold temperature performance
1 - 3 of 3 Posts
