At $2500 it sounds a bit pricey to me, with that mileage.
What's a good price then?At $2500 it sounds a bit pricey to me, with that mileage.
As you are talkiing in dollars should we assume you are in the U.S? I for one have little knowledge of the American car market but in the UK you could probably pick up an X Type of that age for 600-700 GBP. So if the exchange rate is 1.30 dollars to the pound that would be about £1900 here and I would be amazed to see a 2003 X Type for that much money in the UK.What's a good price then?
See if you can get your mate to do a hydrocarbon sniff test on the coolant tank - the white mush could also be a slightly blown head gasket.When i took the oil fill cap off there was a little bit of white pudding underneath it. Not a lot though. I've definitely seen way worse. There is none on the dipstick that i could see, or any just looking inside the oil fill hole. Oil looked a light brownish amber color, like maybe it was slightly new.
I'm planning to take it to a trusted mechanic i know, hes not a jag mechanic but hes professional and trustworthy.
Thanks for all the advice everyone. It helps alot. Well, the "dealer" suddenly changed the price from $2500 to $2750, says his "boss" won't go any lower. Even though the blue book on it is $2600. So, didn't even bother taking it to a mechanic, I told him I'd give $2000 for it take it or leave it, he wouldn't budge so I left. He tried to get me to let him take it to their shop and "fix" the a/c and also the tires in the front have some cracking on the sidewalls, he said they'd fix the a/c and put some used tires up front and sell it for $2750. I said nope.See if you can get your mate to do a hydrocarbon sniff test on the coolant tank - the white mush could also be a slightly blown head gasket.
The lack of aircon may be a quick fix - just a recharge, or could be a whole new compressor - a big bargaining point.....
Also +1 on the sills - get them checked properly - very expensive to fix properly, not a problem on cars from 2005 on.
A dealer fitting second hand tyres!!!!!!!! wtaf!Thanks for all the advice everyone. It helps alot. Well, the "dealer" suddenly changed the price from $2500 to $2750, says his "boss" won't go any lower. Even though the blue book on it is $2600. So, didn't even bother taking it to a mechanic, I told him I'd give $2000 for it take it or leave it, he wouldn't budge so I left. He tried to get me to let him take it to their shop and "fix" the a/c and also the tires in the front have some cracking on the sidewalls, he said they'd fix the a/c and put some used tires up front and sell it for $2750. I said nope.
Oh and I could swear yesterday there was 134k miles on it, and today it magically has 124k... Maybe I'm just losing my mind............. Right.
