Is the noise more pronounced when you turn sharp left or right whilst moving? try with the windows down to see where the noise is coming from
OK! I'll check. ThanksIs the noise more pronounced when you turn sharp left or right whilst moving? try with the windows down to see where the noise is coming from
i am getting that now to be honest i thought it might have been a pad rubbing a warped discs thats why i changed them (they needed done anyway)Is the noise more pronounced when you turn sharp left or right whilst moving? try with the windows down to see where the noise is coming from
seems to get a little deeper bassier when you turn yes and its from the front rightIf it's a wheel bearing you can feel the 'play' with your hands. Go to each wheel in turn and grab hold of the top of the tyre (whilst stationary!!!)
Pull and push the top of the tyre as hard as you can. You should not feel any movement. If the wheel bearing is worn, you will feel a slight amount of play, maybe a very faint knock through your hands.
As has been said already, does it get louder when cornering? Is it coming from the front or back of the car?
This is better, but not necessary. The play in a worn bearing can still be felt if the wheel is the ground. DO NOT RAISE THE CAR WITH A SCISSOR JACK AND THEN START ROCKING THE WHEEL!!Don't forget to do this with the wheel off the ground...
