"Special Tools" to remove transfer box
1 reading
1.9K views 2 replies 2 participants last post by  Grolschie
Hi Guys,
after a close inspection my box is leaking and garage would like to get it off.
The JTIS cd says "special tools" are required, the garage has identified 3 that it needs. Jagiar do not sell these tools to independents, so my questions
are these "special tools" really needed or can things be done anyway?
Thanks in advance
#2 ·
here is what he thinks he might need, i've included prices from us site too as well as the parts numbers.
slide hammer adaptot 10001203 $17.68
adapter nut 20549101 $69.65
forcing screw 204269 $55.04
link shaft oil seal installer 205115 $104.18
what do you guys think?
#3 ·
Re special tools,almost any so called special tool can be made by any component engineering shop if the threads/specs are known.
simply strip the box as far as possable then as the special tool is required you can measure threads ect and have it made at a lot less than stated prices.
Slide hammers are common place it is just the simple adapter on the end that you need to made.
