Joining two electrical wires together and it seems as though I have been doing it all wrong for the past 45 years or so, or rather let’s say there were better methods I could have used. I have some tips, tricks and ideas that could be of interest to other ‘novices’ like me, as I have I had my eyes opened to the world of splicing over this past week. It all started when I extended the flex to the battery charger of my Merc, which was too short to reach the outside waterproof box and be able to under the car and car cover for added protection. Now you may not find the subject quite as fascinating as I do, small minds and all that, but I have spent many happy hours checking out articles and YT videos on various devices on and around the subject. I have also made a number of purchases (well you know me), that will make my future endeavours on the joining of wires both easier, safer and more fun – whoopie!
The reason for this post is to share some of what I have learnt and give you a little food for thought, which I hope some members might find beneficial. But I hasten to add, it is very low key and not for those oh so knowledgeable ones on the forum, so for those please excuse my excitement over what you probably will find quite trivial.
Here we go then without further ado, and these are the things I have been looking at:
1) To splice electrical wires: joining together two (or more) wires so an electric current can pass through them
2) Butt Splice Crimp Connectors
3) Butt Splice Terminal End Crimp Connectors
4) Heat Shrink Wire Crimp Connectors
5) Solder Seal Heat Shrink Wire Butt Splice Connectors
6) Soldering a spliced wire joint
7) Care of and Tinning a Soldering Iron
8) Connectors & tools etc. some good some not so good?
NB: all examples will be given involving 2 wires to keep things simple.
You would not believe how many different ways there are on the internet of how to splice two wires together in the most basic sense, the way I used to do it was to twist them together lay them flat along the plastic sheath and cover individually with insulating tape and then go over the whole flex again covering all the wire(s) with yet more tape. Then of course when I heard of the Heat Shrink Tubing I would use this to cover the joint and then go over the lot again with insulation tape, especially if the wire was going outside/in conduit.
Apparently this is a very weak kind of splice and it can easily be pulled apart, just as well as far as I can remember, none of my splices would have been put under any kind of force to lead them to separate ... well, nothing stopped working as a result of a break in a connection anyway.
Here are just two basic methods of splicing both of which profess to give a strong joint aided by the use of heat shrink tubing.
These connectors require the plastic coating to be removed to expose just enough wire to sit inside one half of the connector and butt up against the central barrier, and the same for the other wire the other side. Each wire is crimped firmly to make the connection and hold it in place, at this point it is NOT waterproof so adding heat shrink tubing will correct this by sealing in the spliced joint.
Sensitive content, not recommended for those under 18
Show Content
