Steering wobble when braking SOLVED
739 Views 28 Replies 10 Participants Last post by  Deadpool
And so it begins Well i got 3 and a half months out of it.
Today just out of the blue I noticed a wobbling sensation when driving and when braking a noticeable visual wobble on the steering wheel. Wheel Nuts are tight
Before I throw it in for balance and alignment any thoughts?
My thought was discs but it was to sudden, and that wouldn't cause a wobble when I'm driving normally would it?
21 - 29 of 29 Posts
It could be just the slide pins. Rather than a piston. There may be a jaguar rebuild kit too.
Reactions: 2
Update: Calliper sticking, pads worn to the knuckle. Discs scored. Its in the garage. Dont want cheapo bits put on, OEM out of the question if I want to eat next year. Brembo any good? AA guy I was talking with is a jag fan, Doing up an S type he said hes put the disks and pads on his.
Reactions: 1
I’ve used Brembo discs and pads to good effect in the past with non-Jaguars. Also testing them out on a family member’s JLR and all good so far. In fact, they are my first port of call as an alternative to (often daftly priced) main dealer, unless your driving style is ‘enthusiastic’ and something more specialised from the likes of EBC may be effective.
Cheers, Only get enthusiastic rarely, most times I drive like a grandad in a jag.
Reactions: 1
I had the same issue at around 24,000 miles on my XE. Had to replace both discs and pads. The slide pins were dry, and sticking badly in their bores and it appears that Jaguar don't apply any lubricant to them when assembling new.
I cleaned the pins up with metal polish and smeared them with silicone grease before re-assembly. I used EBC discs and their Redstuff ceramic pads which are not the cheapest but are less than Jag OEM. At 29,000 miles the brakes are working fine with no signs of the disc scoring that I previously had
Reactions: 1
Caliper sticking was always favourite LG, shouldn't take much to clean it up and sliders etc lubricated and working well.
I know Dougie at Prestige used Brembo in the past, unsure what he uses now
Reactions: 1
Front pads are made by and stamped Jurid 310. ATE sell discs which are probably the same as the jaguar OEM.
ATE pads are probably Jurid 310 as well.
You may find the Brembo pads are not DOT rated as well as the original items which are GG.
Reactions: 1
oh for the days where you could go in a shop and say brake pads for a ford cortina and a box was planted on the counter.
I would go to the motor factors and they would plonk them down then I would go home swear and go back. No matter what car I get it always seems to be the one they made 5 off on a Friday afternoon. My mate suffers from this problem as well.
21 - 29 of 29 Posts
