I'd be more concerned about why you've got uneven wear on front tyres!
I dont have uneven tyre wear, I have a nearly new tyre and an old worn out tyre!I'd be more concerned about why you've got uneven wear on front tyres!
I have only owned the car a couple of months, I would never have different tyres on the same axel, the front passenger tyre is nearly new hence not really wanting to get rid of it, but I will change them both reverting back to the jaguars spec if its deemed necessary, hence coming on here and asking the question. I am not a cheap fly by night STR owner, I got the car reasonably cheap as I knew I had to spend some money sorting it out which is what I am doing, just don't want to spend money unnecessarily.Y is the speed rating (186mph)
The 96 or 100 is the load rating
96 = 710kg per tyre
100 = 800kg per tyre
I would stick with the standard profile, do not mix tyre brand, size or spec on the same axle.
And in future change your tyres in pairs, if not full sets.
As above should be 245 40 18I have only owned the car a couple of months, I would never have different tyres on the same axel, the front passenger tyre is nearly new hence not really wanting to get rid of it, but I will change them both reverting back to the jaguars spec if its deemed necessary, hence coming on here and asking the question. I am not a cheap fly by night STR owner, I got the car reasonably cheap as I knew I had to spend some money sorting it out which is what I am doing, just don't want to spend money unnecessarily.
Thanks to all that have replied.
