Hi all,
Some advice needed. When I go over rough ground or a pot hole etc I can hear a rattle coming from front drivers side. Sounds like something very slightly loose. If I go over the same spot with the brakes even slightly engaged I get no sound so, presumably, something in the brake set up there isn't quite right. Any suggestions as to what it would be?
The noise isn't massively loud but it there, even on relatively minor jolts to the car.
Cheers all,
Martin
Cheers all,
Martin
