1 - 10 of 10 Posts
Hi, guys. Having spent the last 3 years in a vw R32 and GTI, both with aftermarket exhausts I'm used to a bit of noise lol. What's the easiest/cheapest way of getting a bit of noise from a 3.0d s without compromising performance? I'd like to hear that v6 if possible lol.
Think you might be hard pushed to get a good grunt sound from the 3L TD I had some new back boxes fitted and it only made a slight difference in the sound on my V6 TD but it was looks not sound I wanted so you might need to look at the whole system even then I suspect you would have to have the DPF deleted to get any change in sound.
Get yourself a decent CD of great engine sounds and play that at high volume:-D
You could always give the neighbours a treat and leave as it is, much better than pi$$ing them off all the time, it would me! Phil
"Pace with Grace", not a Ford Focus with a hole in its exhaust.
TBPH, if you want the throaty sound you ought to look for the R (petrol) variants. The 5.0L V8 with its supercharger sounds more sporty. The diesels are designed to be quiet.
Varex Mufflers
Not listed on their web so you would need to order by size
1 - 10 of 10 Posts
