I have a misfire which varies in severeness.
Also at about 4500 - 5000 rpm the tacho drops to zero, picking
up again once revs drop to about 4000.
It has a ReOpus ignition amp.
I use NGK Iridium plugs, previously I have run these with the
engine being turbine smooth.
Anything special to check before I start going systematically
through it all? In particular the tacho dropping indicates to
me I have a general problem possibly in the low voltage
circuit?
circuit?
