1 - 2 of 2 Posts
I had my x type estate through it’s mot recently and the test station were concerned about a metal framework bolted to the sub frame, the rest guy didn’t know what purpose it served however the car has a factory fitted witter removable tow bar. I personally haven’t seen this framework . Also waste seals on the estate rear windows, easy to replace or not ??
The waist seals are easily replaceable but expensive.
Not sure about the metal framework but if it is the towbar bracket then it is bolted to the rear subframe.
1 - 2 of 2 Posts
