Mack1955
Hi guys, smoke from near side front when starting from cold had loads this morning quite embarrassing really, have been told to disable webasto by removing relevant fuse is this ok to do or can it harm engine
Smoke from the Webasto is normal particularly at the first cold snap. It only works if aircon is on and temp is 5 deg or below. It is there to provide heat in the cabin much quicker than would be the case if waiting for the engine to warm up. All diesels are renown for taking an age to get warmed up. If this is your first winter with the car I would try letting it do its thing before removing fuses as the smoke tends to reduce after a little use and the benefits are well worthwhile. As mentioned if you particularly want to avoid the smoke, wait until you are on the road before turning the aircon on.Hi guys, smoke from near side front when starting from cold had loads this morning quite embarrassing really, have been told to disable webasto by removing relevant fuse is this ok to do or can it harm engine
Thanks for the reply I’ll take your advice see how I get on this winterSmoke from the Webasto is normal particularly at the first cold snap. It only works if aircon is on and temp is 5 deg or below. It is there to provide heat in the cabin much quicker than would be the case if waiting for the engine to warm up. All diesels are renown for taking an age to get warmed up. If this is your first winter with the car I would try letting it do its thing before removing fuses as the smoke tends to reduce after a little use and the benefits are well worthwhile. As mentioned if you particularly want to avoid the smoke, wait until you are on the road before turning the aircon on.
It won't damage the engine as such but we all know wear happens with a cold engine, the Webasto helps (massively) getting the engine up to the correct temperature.Smoke outside is not a problem... The cabin completely fills with smoke this time of year, happened last year as well. undrivable until clear of smoke and fumes. they also said it was making a noise. Not that I've heard it. what damage is it likely to cause to the engine?
