So I have another set of wheels to fit on the XK, not sure I will keep these on or not, I have gone down to 19” for a bit more give in the tyre wall, but I’ll see what they look like once they are on, if I don’t like them I’ll have the originals refurbished and made round again as one has a flat spot, however I can’t do any of that until I can get the driver side rear wheel off, all nuts are stuck apart from the one I fitted to replace the locking one, two have snapped off and I believe a hole saw is the answer to this, I suspect the other two will snap as well, oddly the car was fitted with tyres not so long ago and the rest are ok, all we’re done to the correct torque, so how did the idiots manage to over tighten just one wheel?
Any way it is the right time to replace all the wheel nuts, does anyone have the link to the solid one piece alternatives or should I stick with the original type and only tighten correctly?
