Hi
My x350 V6 2003 throws up intermittent DSC faults. My dealer, with some help from Jag, believe it is EITHER the Yaw sensor OR DSC module. However they need it in fault state to determine which, and it is an intermittent fault. (arghhh!)
Unfortunately new prices are £211for the Yaw sensor and £475 for the DSC module (plus VAT plus fitting)!!!
An alternative is to replace each module with a reliable second hand one, so I am looking for sources (guaranteed or re-conditioned ideally).
The parts numbers (from my dealer) are:
JAC2C 26939 - D.S.C MODULE
JAC2C 34671 - YAW RATE SENSOR
Can anyone recommend a reliable (and cheap) source please?
Also I think the Yaw sensor may have another part number (ones on ebay show a ford branded item) which is 2M5T-14B296-AC. Does anyone know if this is correct?
Many thanks
Phil
