1 - 4 of 4 Posts
Hi, driver's side window won't fully close up and so can you can hear slight noise through the very top. Does anyone know if I could make an adjustment myself to correct this?
Just had this same issue fixed on my Sportbrake recently. At first, resetting the window seemed to fix the issue, but it came back after a short period. Had the dealer look it over, and after they went through a few different things, it turned out the window seal was tight, which caused the window to bind towards the top (stayed open about an 1/8"). They ordered a new driver door window seal and swapped out the old one. Been about a month now and haven't had the issue come back since.
1 - 4 of 4 Posts
