1 - 9 of 9 Posts
Hello guys
Drove my car Friday, no problems. Came out this morning and all i got was clicking. All lights on the dash came on, and the radio came on.
Turned the key, loud clicking and dash lights flickering. Also, red alarm light flashing. I am also able to move the gear lever from P to N. Read about loads of possible causes, but i think mine is too many short journeys. I am now charging the battery overnight and will see how it goes tomorrow.
I have also changed the battery in key fob. Is there anything i should do or look out for after i put the battery back in?
Any help would be much appreciated.
Lee
It's a flat battery.
Get it charged then check your alternator and charging circuit is working correctly.
You will need to charge it for about 16 hours, not on fast charge though. Then follow the previous suggestions.
Thanks for the replies guys.
So recharged the battery overnight. Put it back on the car and it started straight away.
Now i have the yellow engine light on and it stays on. Is there something i have do to make it turn off?
Many thanks
Lee
Mine did the same after a flat battery, It brought up a can comm code, cleared it no dramas since. It was most likely due to the non start condition and low voltage when it was trying to turn over.
1 - 9 of 9 Posts
